Beogram 3300 - Arm lowering differently at the beginning and at the end
GleBufsen
France
Posts 8
GleBufsen Posted: Fri, Mar 21 2014 4:04 PM
Dear Community,
Here is the situation on a 1986 Beogram 3300 deck:
The arm lowers when I press "play", except that at the beginning of the disc, the diamond doesnt touch the disc (3 mm too high), and at the end of the disc, the cartridge is very close to the disc, the stylus suspension looks squeezed... As if the rail was not parallel to the deck, but when looking inside the deck, it looks like it is!
Visually:
Is this something you have already seen? I have gone many posts before sending this one, and couldnt find a similar situation... Let me know if you need any clarification.
Thank you for your feedback!
G
joeyboygolf
Ely, Cambridgeshire, UK
Posts 4,188
Check that the chrome bars that the moving carriage slides on are pressed into the plastic clips at both ends.
Regards Graham
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Fri, Mar 21 2014 6:02 PM
What Graham said.
GleBufsen
France
Posts 8
GleBufsen replied on Wed, Mar 26 2014 10:38 AM
Hi Guys,
Ok thanks a lot for your fast responses, I'll check what you are suugesting, although when looking at it and even trying to push the chrome bar without removing the full cover of the deck, it looks in place already...
G
GleBufsen
France
Posts 8
GleBufsen replied on Tue, Apr 15 2014 12:46 PM
Hi joeyboygolf and Dillen,
thanks for  your advises. I finally saw there was a second chrome bar (a bit hidden under the cover) on which the arm slides, and this one was off the clips. I pushed it back in and it is working perfectly now!
G
Dillen
Posts 13,191
Dillen replied on Tue, Apr 15 2014 3:48 PM
Good job !
Don't be a stranger now.
MechMusic
Posts 2
MechMusic replied on Tue, Mar 26 2019 5:04 PM
Apologies if this should be a new post, I wasn't sure as it is somewhat related..
My problem is that since fitting a new cord on my beogram 3300, everything works fine except that the slider, when returning to rest position, hits the endstop and vibrates a bit as a result.
I think the 'knot' is in the correct position on the wheel, and I did try adjusting the off-center wheel that the spring on the chord attaches to, but this did not cure it. The tone arm moves and drops to the correct position for LPs and singles- it just is a bit unrefined by hitting the endstop when resting.
Any help much apreciated.
MechMusic
Posts 2
MechMusic replied on Thu, Mar 28 2019 6:42 PM
I've had another look over how the slider is running on the metal rail. It appears that it does not actually hit the end-stop, but the tone arm still judders when it comes to final rest after play has finished.
I've checked the metal bar that the slider runs on- it is firmly clipped on at both ends.
Page 1 of 1 (8 items) | RSS
