Beocentre 9500 Cassette recording problem
This post has 6 Replies | 0 Followers
Jokeruk
Posts 5
Jokeruk Posted: Thu, Apr 4 2019 8:13 AM
Hi all,
‘just reunited myself with B&O after many years through the purchase of a Beocentre 9500 - one of the reasons being to record cassettes to use in a car I’m restoring.
The Beocentre is immaculate with all sliding parts working correctly. CD reads and plays instantly, however it will not record to cassette.
‘The record process kicks off fine, the VU meter bounces away but on play back there is little sound - by little I mean little more than static with a hint of the original source buried in the background, maybe just a small beat.
Any suggestions on where to start looking would be gratefully received, I have some electronics background and so don’t mind disassembly and soldering. I have a couple of decent voltage meters.
oh yes, one more thing the cassette mechanism seems to give an occasional shrieking noise
regards
steve
Keith
Shrewsbury
Posts 138
Keith replied on Thu, Apr 4 2019 11:12 AM
Have you replaced the cassette player belt/s ?
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Thu, Apr 4 2019 12:47 PM
Will it play prerecorded tapes?
Jokeruk
Posts 5
Jokeruk replied on Thu, Apr 4 2019 3:56 PM
Hi there, I was told they had been replaced prior to purchase - and it plays tapes fine (I managed to find a prerecorded one)
Jokeruk
Posts 5
Yes Martin plays fine
Dillen
Posts 13,191
Dillen replied on Thu, Apr 4 2019 4:29 PM
Sounds like a BIAS problem.
Check the BIAS oscillator.
Jokeruk
Posts 5
Jokeruk replied on Thu, Apr 4 2019 6:27 PM
Thanks for your diagnosis Martin.
I have a circuit diagram on which I can see BIAS OSCILLATOR labelled.
Is there an obvious component in that area I should look at ?
Thanks in advance
Steve
Page 1 of 1 (7 items) | RSS
