Hi all,
I'm new to B&O and just recently purchased some vintage gear.
I ended up with a Beocenter 7000 with some beovox S30's and Beovox 2400 speakers.
The beocenter 7000 was in reasonable shape but the tape deck and tone arm return weren't working properly. After some tinkering and regreasing of the tone arm lifter I was able to get that working but the tape player needs some new bands. I also broke the plastic hinges when opening up the control unit while i was working on it.
As for the speakers the S30's are in pretty good nic but one of the connecting plugs has been cut off the 2400's
Does anyone know where i can get some tape bands, replacement plugs for the 2400's and also if replacement hinges are available?
I live in Australia and found some Bands On ebay but the shipping was 3 times more that the bands were. The plugs and hinges i havent had any success finding yet.
Any help would be greatly appreciated.
Thanks all
From the New B&O Guy!
I can supply correct belts, idler wheel rubber parts etc.PM or email me.
