Beolab 11
This post has 18 Replies | 1 Follower
mivsbai
Posts 77
mivsbai Posted: Sun, Oct 14 2012 8:16 PM
Hi
I have a pair of beolab 3 and beolab 7.1 currently connecting with an AV receiver as my front speakers. Now I would like to add a sub into my system. I have read a few threads about beolab 11. It seems to be a very good choice for beolab 3s. I use my system half for music half for movie. And my living space is about 40-45 m2. Do you think beolab 11 would give my system a real boost for both music and movie? Or do i need the more powerful beolab 2?
The problem with beolab 2 is I am worried it might be too powerful for beolab 3s, as you might known, the beolab 3s have crystal clear sound, would beolab 2 give too much 'boom' that might destroy the pure sound of beolab 3? However, I am not sure would beolab 11 be powerful enough for my room size and for some action movies?
Tony
Mdjolly1973
Posts 51
I have the lab 11 and the lab 2 in another set up,the 11 is a lot more discreet and packs a punch when needed however the lab 2 is very boomy of which i only have on the lowest setting.....
Depends how much of a impact you want!
Cheers
Mark
BeoHut
Posts 482
BeoHut replied on Sun, Oct 14 2012 8:41 PM
mivsbai:
That's ecactly the reason why I sold my BL2. I'm very satisfied now with the BL11. I have almost the same roomsize you mentioned. Try a demo at home from your dealer and you will hear the difference.
mivsbai
Posts 77
mivsbai replied on Sun, Oct 14 2012 8:59 PM
Mdjolly1973:
Cheers
Mark
Hello Mark
thanks for your reply, what speakers are you using with beolab 2 and beolab 11? Would beolab 11 be good enough for movies? Well, I don't expect room shaking experience, but I do hope beolab 11 can bring some 'special effect'
mivsbai
Posts 77
mivsbai replied on Sun, Oct 14 2012 9:02 PM
Beofan53:
mivsbai:
Hi, are you using beolab 3 to pair with beolab 11? As we have similar room size, maybe you could give me a better opinion on how good is the beolab 11 for moives? Can you actually feel the bass when you want?  Well, for sure beolab 11 is great for music with beolab 3s.
Cheers
Tony
mivsbai
Posts 77
mivsbai replied on Sun, Oct 14 2012 9:05 PM
Hi beofan 53,
I am going to use the updated new system in my new home in anther country, so I am afraid a home demo is not possible currently.
Mdjolly1973
Posts 51
Hi,im running 4x lab 8000s and lab 11 in living room and a bit overkill in the bedroom but 4 x lab 3's and lab 2 in the bedroom
mivsbai
Posts 77
mivsbai replied on Sun, Oct 14 2012 9:44 PM
Hi mark
You have really good taste, 8000s and 3s are my favorite speakers in design wise. The only reason I did not buy 8000s is they look a bit to tall in my room decoration. Btw, would lab 11 be powerful enough for 4 8000s both for music and movies? what is your room size if you don't mind answer?
Tony
Mdjolly1973
Posts 51
I think the lab 11 is a more 'livable' speaker of the two....my rooms about 40ft x 25ft and it more than copes! Im thinking bout trading my 8000s and lab 11 for the beolab 9's and lab 3's at the rear......
BeoHut
Posts 482
BeoHut replied on Sun, Oct 14 2012 10:18 PM
mivsbai:
Cheers
Tony
I use my BL11 in combination with a set of BL12-3's (front) and rear BL4000's.
No sound adjustment is necessary. Perfect for music (more body, a tight bass, extra deep tones for music without the booming effect). Also perfect for movies (even set the subwooferlevel a bit higher, but not necessary). Do not expect earthquakes, but perfect and enough for a big punch with movies. I still have no regret of this tulip sub.
mivsbai
Posts 77
mivsbai replied on Sun, Oct 14 2012 10:47 PM
Mdjolly1973:
wow, 40x25ft is a very large room, if you say bl 11 is livable in your room size, I think bl 11 would be more than enough in my room. And yes, for your room size, a pair of bl 9s and bl3 would be perfect. I like the sound of bl 9s, but Personally, I prefer the design of 8000s and 3s.
mivsbai
Posts 77
mivsbai replied on Sun, Oct 14 2012 10:49 PM
Beofan53:
mivsbai:
Cheers
Tony
That is enough, that is all I expect from a sub, from your experience, I really think  bl 11 would be a perfect solution for my system.
moxxey
South West, UK
Posts 5,359
moxxey replied on Mon, Oct 15 2012 7:22 AM
mivsbai:
I've owned just about every speaker combo that B&O have provided (BL8000s aside) and i'm most happiest with my BL3+BL11 setup, particularly for music. It doesn't make a huge difference, but that small change does make the sound more 'rounder' and, of course, slightly more bass.
However, BL9s are much better for movies and the BL3+BL2 combo would be better for movies, too.
Mdjolly1973
Posts 51
Moxxey:
Im about to trade in my lab 8000s lab 11 combo for lab 9's lab 3 combo-good choice?
moxxey
South West, UK
Posts 5,359
moxxey replied on Mon, Oct 15 2012 12:21 PM
Mdjolly1973:
Moxxey:
You can't go wrong with the lab 9s, in my opinion. 9s at the front, 3s at the rear?
Mdjolly1973
Posts 51
Just done the deal !
Bv7Mk3
uk
Posts 781
Bv7Mk3 replied on Mon, Oct 15 2012 1:33 PM
Was it a good 1?
mivsbai
Posts 77
mivsbai replied on Mon, Oct 15 2012 2:12 PM
moxxey:
mivsbai:
I have heart bl 9 at my local dealer, they are amazing. But I have problems to place them in my room according to my odd room decoration, I guess bl3 + bl11 would be my best solution. And moxxey, can you please give some opinion on how close the bl3+bl11 combo compares to bl9 in overall performance for both music and movie?
Mdjolly1973
Posts 51
I think so :-/
Page 1 of 1 (19 items) | RSS
