B&o Playmaker, 2-3 Second delay
This post has 6 Replies | 0 Followers
Bech312
Posts 2
Bech312 Posted: Wed, Apr 10 2019 5:14 PM
Hi.
I have an issue with my playmaker. The problem is there is some kind of delay when playing music.
The playmaker is connected to my router with a cat6 cable, and is playing through two beolab 3. I’m using Spotify to stream. The volume reacts immediately, but when switching songs there can be a delay of 2-3 seconds before playing the next song when switching.
Is this normal for the playmaker? I tried searching the forum with no result.
Bonus Question: is there a smart way to hide the playmaker and still be using a beoremote to control the volume.
Jeff
USA
Posts 3,793
Silver Member
Jeff replied on Wed, Apr 10 2019 5:35 PM
The delay when switching songs is normal for Spotify and most other services like that. It's due to buffering, in order to reduce the effect of temporary network dropouts the music is buffered for a few sec, so quick dropouts don't result in the music dropping out, though longer ones can cause interruption. Was that way on my Playmaker, is that way on my Auralic Mini. When I'm playing songs off the internal hard drive of the Auralic though it responds instantly. It's buffered in the device doing the Spotify app, not in the Playmaker as far as I know.
You need something to get the IR signal into a closed cabinet. I've seen people use the little eye from a peephole like you use in your front door for this, put it in the cabinet door in front of where the equipment goes, though not a great solution if you want to keep the cabinet pristine. Fortunately the IR remote, like the Beo4, puts out a lot of power so maybe if there is a crack? Of course you also can set it to a fixed volume and control the volume from your iPad or such, though thats a tad cumbersome tome.
Jeff
Robin
Nrw
Posts 107
Robin replied on Wed, Apr 10 2019 11:09 PM
How can you set it to a fixed level?via audio option? Is it automatically set to maximum?
Jeff
USA
Posts 3,793
Silver Member
Jeff replied on Thu, Apr 11 2019 2:21 PM
I don't remember how to do it now, but it's in the instructions. I seem to recall it took a certain series of button pushes on a Beo4 remote to move it into fixed output. I used it that way into the tape inputs of my Beosound 9000.
Jeff
Robin
Nrw
Posts 107
Robin replied on Sat, Apr 13 2019 11:34 PM
Still trying to use it with my beocenter 2 for the aux inputs. Another problem: I would like to use 2 sources for aux input [:\'(]
Jeff
USA
Posts 3,793
Silver Member
Jeff replied on Sat, Apr 13 2019 11:48 PM
Plug one source into the aux inputs on the Playmaker, then plug the Playmaker into the BC2. The Playmaker will auto select its aux input when there's a signal there. Not sure if the streaming overrides the input or not, but if you stop streaming it'll pick the aux if there's a signal there. I ran the output of the phono preamp I use with my Beogram into the Playmaker that way and used it for a long time.
Jeff
Robin
Nrw
Posts 107
Robin replied on Sun, Apr 14 2019 10:58 PM
Will give it another try. Last time, I’ve tried this. The volume was very low, coming from the pm. Tv —> pm —> bc. Thinking about a box from Armando. But 300/400€ is quite a bit
Page 1 of 1 (7 items) | RSS
