I am looking into a projector for my living room. I currently have a BV7-40. I would love to have some feedback from the forum concerning projectors and screens.
Thank you in advance for your good ideas !
- Scott
Hi
I recently bought a used samsung sp-a600b wich is in the puc table and is verry great
hello again,
i have a bv7-40 mk5.
i looked through the puc table and i did not see many projectors. where are you getting codes, from dealers ?
- scott
I'd say if you have 5-6K to spend I would look at the new Sim Cube or the JVC Reference series. For less than 6k it doesn't get much better in my opinion.
Ah, you know... A little B&O here, a little there
I am using an Optoma HD65 on my BV7 MK3 with 2 speaker setups as the screen is on another wall
well satisfied with it
Hi there
I have the BV7 MK4 and I am also using the Optoma HD65 beemer without PUC. I use a lintronic -238 to activate everything when the bins on the BV7 cinema output are activated.
I also use a motorised screen from Optoma its their Panoview.
My setup is excellent and cost a little over £500.
Screen drops down in front of the TV to just over the beolab speaker so I keep the same speaker config.
Good Luck its well worth it.
Eclipse 65V1-32Beosound M5Essence MK2BLI
I got a Sony VPL-VW1100ES Native 4K Projector last December to be a gift for my family, cause I planed to watch movie with my family on the Christmas night with the feeling of cinema. It worked very well and I set it up in my living room. The one I got with the size of 29.1*26.8*13.4, the contrast radio of 1000000:1 and the brightness of 2000 lumens. Actually you`d better pay for the one you like after taking refer to the reviews or buying guide of projectors. If you can get a 4k projector the article of comparison of 4k projector here is what I recommend to you highly.
->> https://www.cfone.net/5-comparison-for-4k-projector-on-amazon-com.html
georgey007: Hi I recently bought a used samsung sp-a600b wich is in the puc table and is verry great
Were you able to get the specific PUC for the sp-a600b model? I have that same projector. A year ago, BeoCare told me that they didn't have the entry for that projector and suggested I used the PUC for another Samsung projector. The problem is that the sp-a600b requires a conformation from you that you do indeed want to power down the projector -- which the other samsung projector does not.
