Dear BeoWorld Members,
I am new to this forum and I wonder if you could support with my query .
Hi Alicja
Does the light go out or down?
If the light goes down when the tonearme comes to the recordplatter it seems that the current limiting switch doesn´t work and the current of the tonearm coil draws the power down.
There are two kinds of limiting switches, one is a mechanical switch, pressed by a lever, the other one is an electronic switch realised with transistors, resistors and caps om the mainboard.
Don´t let it in this state too long, the coil will get hot, melt and get damaged.
Best regards
Christian
Hi Christian
Thank you for kind replay and helping out -
The light is out. Currently, after plugging Beogram to power supply, the light does not turn on. I have kept it off since then and I have started looking for a specialist to help ideally in Denmark (or Germany) to hopefully get it fixed.
Best Regards
