Hallo, I am hoping someone can advise. I want to remove the dust cover from a CDX in order to polish the acrylic panel. The service manual isn't very clear. (screen grab attached). The black plastic mated with the alu panel is very thin and from what I gather, prone to breaking. According to the manual this is clicked in somehow. Can anyone advise on the correct direction or technique to get this off.?
Thanks,
Best regards
Mark
