RL 140 woofers replace
carlos76
Posts 2
carlos76 Posted: Sun, Mar 23 2014 6:26 PM
Hi there,
Has anybody replaced the RL 140 woofers? If so, what brand and model did you use? Does aybody know where I can get the specs from the original woofers that mount the RL 140?
Thank you very much
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Sun, Mar 23 2014 7:31 PM
Welcome to Beoworld !
The original T/S parameters are not disclosed but you can start by asking around for 6 ohms impedance woofers.
After spending many weeks looking around only to find out that no producers are making
such things, you'll find your options are:
- Get the ones you have repaired, it's a fairly standard job for a prof. refoamer if they "only" need new foam surrounds.
- Find a set of original woofers that are already refoamed.
I have seen two or three different alternatives fitted in RL140s coming in for repairs here but none of them sounded
anywhere near the original. I fitted back original woofers in them all.
carlos76
Posts 2
carlos76 replied on Sun, Mar 23 2014 10:31 PM
Thank you so much Dillen for your answer. I will take them to have them refoam. I was just wondering  the chances to fit new woofers. I thought the speakers had 8 ohms impedance.
hewber
Posts 3
Silver Member
hewber replied on Sun, Apr 5 2020 1:03 AM
Carlos,
I seek replacement woofers as well for my very old speakers.  Have any luck?
Hewitt Berrien
Oregon, US
Page 1 of 1 (4 items) | RSS
