Beosystem 7000 Connection Question
Manbearpig
Posts 908
Manbearpig Posted: Mon, Jan 21 2019 9:05 AM
Dear members,
is there a way to connect the Beosystem 7000 to the Beosystem 3 directly without the use of a Beolink converter? Reason I'm asking is that I have compared direct connection of speakers to the Beosystem 7000 vs. connection to the TV and link between 7000 and TV (via 1611 converter) and the sound was much better with direct connection of speakers to the Beosystem. This observation leads me to the second question: can the use of the 1611 converter have such a negative impact on sound in your experience?
Greetings,
Kai
DMacri
United States
Posts 881
DMacri replied on Mon, Jan 21 2019 9:20 AM
I did not notice a reduction in sound quality but I’m using my BS3 with DPLII to create surround sound from the BS7000. So any potential quality loss might be masked by the improvement in immersion I’m experiencing.
Dom
2x BeoSystem 3, BeoSystem 5000, BeoSystem 6500, 2x BeoMaster 7000, 2 pair of BeoLab Penta mk2, AV 7000, Beolab 4000, BeoSound 4000, Playmaker, BeoLab 2500, S-45, S-45.2, RL-140, CX-50, C-75, 3x CX-100, 3x MCL2 link rooms, 3x Beolab 2000, M3, P2, Earset, A8 earphones, A3, 2x 4001 relay, H3, H3 ANC, H6, 2014 Audi S5 with B&O sound, and ambio
Steve at Sounds Heavenly
The cable workshop, Leics, UK
Posts 2,165
Dear Kai,
Yes, if you have line of sight to both systems for the remote control then you can directly link the Powerlink output of the 7000 to the red and white RCA audio inputs of the Beosystem 3 (eg. AV4) with this cable to avoid needing the converter:-
https://soundsheavenly.com/bang-olufsen/5-pin-din-to-twin-rca-powerlink-compatible-to-non-bo-hifi-amplifier-receiver-etc-din-to-twin-phono
Please set the Beosound volume to a high level (50-75%) to give you the full range of volume control from the Beosystem 3.
Kind regards, Steve.
Steve.
www.soundsheavenly.com
Manbearpig
Posts 908
Manbearpig replied on Mon, Jan 21 2019 10:03 AM
Thanks for the answers.
@Steve: with that solution, I would need to put the Beosystem 7000 to option 1, wouldn't I?
@ DMacri: any Beosystem 3 does have DPLII, do they?
Probably buying a Beosystem 3 is the best solution for me.
Thanks!
Kai
Posts 2,165
Hi Kai,
Yes, option 1 will work for the 7000.  Beosystem 3 has 8 pin Powerlink outputs, these can work with any B&O powered speakers, via the correct cables, so either newer RJ45 connections or DIN connections are fine.
Steve.
DMacri
United States
Posts 881
DMacri replied on Mon, Jan 21 2019 3:08 PM
Yes, I have two MkI models and they include DPLII, Dolby Digital, and DTS and can run in 7.1 channels. They have analog, coax digital, and HDMI inputs. Very flexible.
Dom
Manbearpig
Posts 908
Hello again,
actually, I'm still not quite sure how to realize this. Connection is clear. But what about option programming? Beosystem 3 and Beosystem in option 1? And TV linked via DVI?
Thanks!
Greetings,
Kai
stefan
200 miles from Struer
Posts 2,920
stefan replied on Thu, May 9 2019 2:10 PM
Why not get a Powerlink switch?
https://shop.oneremote.dk/shop/69067-powerlink-switch/
You connect everything as usual in 0/2 AV setup.
BS7000 and BS3 masterlinked via a 1611 converter - all Beolabs connected to BS3.
Now you disconnect the front Beolabs and connect them to the PL switch input1.
Connect your BS7000 PL output to PL switch input2.
Connect PL switch output to your front Beolabs.
Set BS7000 to A.OPT 1. Set BS3 to V.OPT 1.
Now your BS7000 will be directly routed to your front Beolabs, when you select an audio source - RADIO, CD, TAPE....)
Your BS3 will keep in Stdby mode.
If you select a video sourece, your BS3 will be activated and the BS3 front channels will be directly connected to your front Beolabs.
Your BS7000 will keep in Stdby mode.
If you want an audio source in 1-3-4-5 channel mode (party mode...) press just AV - audio source (AV-CD, AV-RADIO...) and select a SPEAKER mode.
This will route your BS7000 to your BS3 via ML and the PL switch will connect the BS3 input to your front Beolabs.
You have even access to all audio- and video sources in all connected link rooms.
Hope this makes sense...
Stefan
Page 1 of 1 (8 items) | RSS
