Hi Mr Andersen,
Before this sw update in my two A6 and the App update to 2.6.0 everything worked perfect.
I have one Eclipse and two A6 in the same multiroom system.
Now I experience the following bugs:
1. When I start the B&O app one of the A6 everytime will NOT update with NL system so all sources will show upp in the sourcelist in ”now playing screen” to the right. The conequenses of this is that if I start Deezer with the A6 That NOT is ”updated” correctly the MUSIC will start but there is no cover or timeline showing. Sometimes there is no sound. It is not the same speaker that behaves odd everytime. It depends on if the speaker is choosen or not when starting up the BO-app.
2. If I start playing MUSIC with my Eclipse and pusch the multiroom tab and pusch the X for for both of my A6 at the same time they will start up BUT they are very slow to start up and sometimes There is no sound from one of them. It is not the same speaker that behaves odd everytimei. It depends on if the speaker is choosen or not when starting up the BO-app.
There are apperently something wrong with the new sw released some day ago in the A6 OR the new B&O app update to 2.6.0.
I have made completly factory reset on both A6 after sw update but still same sw bug.
Please check this up with the products as I have. I hope you understand my problem.
Overall the A6 is also much slower in the settings menu than before.
Best Regards
Sweden
NEW! Beovision Eclipse 65 2nd generation (G1) with floorstand (from STB Brackets), Beolab 50 front, Beolab 3 rear, 2 x Beoplay A6 linkrooms, 2xBeoremote one BT, Beosound 9000 Mark III (sw 3.4), Beosound 5 (for DLNA only), Philips Hue (all lights in the home), Oppo UDP-203, Apple TV 4K (2021 model). Beoremote HALO, 3xBeoplay Charging pad, Beoplay M5
