Hi, I recently bought a pair of Beolab 18's as rear speakers ( 9's at the front, working with a BV12 ) and have an intermittent popping sound coming from them. I had B&O service team out but of course there were no issues when they were here but next day I got the popping sound again and now most days it happens. The speakers are connected wirelessly to the system.
Any advice or guidance on what I should try to resolve ? Is this an issue with wireless connectivity ? Also, I am wondering whether it is related to the power lead as the speakers are right by the sockets ? But really I have no idea hence the request for help.
Many thanks in advance.
Neil
Beolab 50, Beolab 8000 x 2, Beolab 4000 x 2, BeoSound Core, BeoSound 9000, BeoSound Century, BeoLit 15, BeoPlay A1, BeoPlay P2, BeoPlay H9 3rd Gen, BeoPlay H6, EarSet 3i, BeoVision Eclipse Gen 2 55", BeoPlay V1-40, BeoCom 6000 and so much else :)
Hi, The popping is ongoing on both speakers and not just when they are turned on. It is also intermittent ... Does not always happen and will start / stop at various times whilst operating. I do not see the lights changing color when it happens.
I have tried switching between 3 and 5 speakers to see if that helps but it does not ... No popping when set to three but when I switch back to 5 the popping comes back.
Thanks.
Hello Neil,
I do have a similar sound on my rear BL12.
Mine are connected with CAT7 wires. do you already have a solution for your problem?
Thanks, Heribert
BV 11-46 / Beoplay V1 -40 / Apple TV 1+3 / Beosound Essence MK2 / BL3 / 2* BL11 / BL 6000 / BL 12-1 / BL 2000 / 3 * Beo4 /BL Converter 1611
It makes me think to something related to your electricity installation. You should try to connect your BL to some surge protectors to avoid any power variation which can makes popping.
Does it appear too when switching a light on or off in the same room (ideally same wall where the BL are connected) ?
It could be an issue with 4G interference ,not sure if beolab 18 have them incorporated!.but a filter may solve the problem?!
Heribert, I had the B&O service team out last week and thought they had fixed the problem by changing the output used on my Beosystem 3 for the speakers as the issue went away.
However, a few days later the problem came back although it is happening less frequently now and only when I initially turn the system on.
it is very frustrating and I will probably try a surge protector as someone has proposed to see whether it is the power supply somehow.
This is an old thread but for what it’s worth, here is what I found with BL 8000s. I initially had them connected using RCA from my TV’s variable output jack to line-in. No pops. I later added a BL 2 to the mix to improve the bass. To do this, I made a stereo jack to Powerlink and then connected the BL 8000s to the BL 2s using PowerLink. I now have occasional pops. I believe it is caused by the Powerlink connection. I am using a Furman Power Conditioner and also the power cables were upgraded with Shunyata Venom 14 cables.
In my case the pops are irritating but I can tolerate them for now.
B&O in my life 😊:
Thanks for feedback. Somewhere between moving from Dubai to Tokyo and now to Hong Kong the issue has gone away. I think it was probably a connection somewhere which got resolved with all the unplugging and replugging
