Beolab 4000 switching on from stand-by problems (works only powering it off for 5/10 secs)
This post has 1 Reply | 3 Followers
alfio
Posts 59
alfio Posted: Wed, Aug 16 2017 3:50 PM
Dear All
I have seen a similar thread on forum some time ago, but it did not match the behaviour
problem for my BEOLAB 4000 - S/N 13063449 bought on bay some years ago and used once twice a year as it is in my summer apartment.
I checked the cables extensively and initially I thought they were the responsible , instead finally I was able to reproduce the behavior.
I I switched off the system and leave the BEOLAB in standby for some time it does not switch on. However if I disconnect the power (from the power cable) and plug it in again it works immediately.
If I switch on/off the system in few seconds it works without any problems.
I start thinking about capacitors, but I would appreciate your suggestion and maybe a similar experience.
Tassos
Athens
Posts 323
Tassos replied on Mon, Sep 13 2021 11:37 AM
Hello all I am experiencing the same issue with alfio, any suggestions?
Page 1 of 1 (2 items) | RSS
DigiCert Secured Site Seal
