Hello everyone...
I am new to the Beolit 600 type 1501... I am trying to hook up a line level device like a cd / bluetooth / iphone.
There is a 5 pin din connector with a phonograph / tape deck icon... and I think you have to depress two selector buttons... to select the din as the active port....... but tape would be line level but phonograph is not.... ! i have to assume its a mono source ... so which pins are for line level in and which used for phono level....
I figure I can buy a Din to rca and if i am lucky one the rca will be line level in and the other would be the phono level in....
also I cant seem to find a owners manual for the Beolit 600 type 1501 , i was able to find the service manual...
Thanks everyone...
Best
Bill Sohne
PS I did find the polarity of the 7.5v via searching the forum !
