Beocenter 2300 erpom failure - bin file wanted
tsirvoul
Posts 1
tsirvoul Posted: Fri, May 24 2019 7:44 AM
Hi there
My name is Petros and i live in Greece.
I am a professional techisian and i have a Beocenter 2300.
Yesterday i find out that the system is dead, and the only thing thah works is the light and the power led!!!
I tested all the voltages on the power sypply and is all ok.
Then i notice that the shielded  pcb with the eprom and ram is very hot! I remove the shield and i discovered that the 27C512 IC3 ROM chip is extremely hot. I remove it form it base, and when the is cool down i read the data with my programmer and i find tha the ghip is empty !!!!!!!!
Does any of you find this failure again ? and the most important, haw enyone the bin file for this chip, in order to repair my beloved B & O ?
Thank you in advance for any help
Petros Tsirvoulis
Page 1 of 1 (1 items) | RSS
