Hi wondered if i can have some help just picked up a beocenter 9000 with cx100 speakers and would like to fit a turntable do i need a pre amp or can i put a normal deck on it or what B&O turntables will fit also looked at a granovox vertivle table but not sure ...please help...confused . com
I believe you want one of the Beograms with a built in pre-amp or to use a separate pre amp. I have a Beocenter 9000 with a Beogram 9000 connected which worls well and can be controlled with a beo4 remote which is fun
