Masterlink Connection to a DVB HD TV
This post has 15 Replies | 0 Followers
Tim84
Munich
Posts 98
Tim84 Posted: Wed, Jun 12 2019 9:39 PM
I have a BV 7-32  in my Bedroom with HDMI and DVB-HD, can I connect my BV7-40 in the Livingroom to that TV so i have Access to the HDMI Ports and the DVB HD Tuner? The BV 7-40 is a MK I TV without HDMI and DVB HD but I love it´s DVD Player.
Living room: BeoVision 7 MKV + BeoLab 7-2 + 2x BeoLab 8000 + BeoLab 2 + 2x BeoLab 4000
Office / guest room: BV 7-32 MKIV / BL7-1; BeoSound Core + Turntable
Kitchen: BeoPlay M3
Bathroom: Gira Radio + BeoLab Celestial
Entrance: BeoPlay M3
BEOVOX141
Denmark, West
Posts 711
BEOVOX141 replied on Thu, Jun 13 2019 5:50 PM
Unusually you have the 32 with HDMI and the 40 without, had it only been the other way around....
You have the Cinema output (Display 2) connect that to a HDMI converter and run a SCART cable.
FORMAT 0 will then switch between the two displays and you be able to distribute HD video...
Let me know if you get the general idea?
Millemissen
Flensborg, Denmark
Posts 14,680
@BEOVOX141
As far as I remember rhe 7-32 with the two HDMI -ins had a VGA-output for the second screen.
Correct me, if I am wrong!
BEOVOX141
Denmark, West
Posts 711
BEOVOX141 replied on Thu, Jun 13 2019 7:18 PM
Millemissen:
@BEOVOX141
You are properly absolutely right! So something as simple as this might actually do the trick, since HDCP is not an issue. What do you think?
VGA-DVI adaptor
VGA til DVI-adapter L-Link LL-AD-1115
Tim84
Munich
Posts 98
Tim84 replied on Thu, Jun 13 2019 8:42 PM
I get your idea. I also have a vga to hdmi Converter lying around and a 10m hdmi cable.
Can I then control the BV 7-32 via the Beo4 from the Livingroom? What is the scart for? Audio?
Kitchen: BeoPlay M3
Millemissen
Flensborg, Denmark
Posts 14,680
BEOVOX141:
Millemissen:
@BEOVOX141
VGA-DVI adaptor
I have a few of them lying around from earlier on, I guess.
But it won’t help much - VG/DVI carries no sound.....and how about controlling 🤔
Millemissen
Flensborg, Denmark
Posts 14,680
Tim84:
VGA is an analog signal - no way to connect to HDMI (which is digital.
Only way (and I would not recommend it) could be use the VGA to a scart converter (connected to one of the scart connections on the 32) and add a sound signal from one of the scart (out) connections on the 7-32.
I see no way to control that from afar.
How about getting a small BVB-HD tv box for the 7-40 instead?
BEOVOX141
Denmark, West
Posts 711
BEOVOX141 replied on Thu, Jun 13 2019 9:28 PM
Millemissen:
I know, but the original poster mentioned Masterlink so the sound is there, getting it to play might be another matter. I have never had the privilege of meeting a Beovision 7-40 MkI, but I am guessing its possible.
Edit: I did not see your second reply...
Tim84
Munich
Posts 98
Tim84 replied on Thu, Jun 13 2019 9:32 PM
Thanks for your Help :-)
I will try a bit with all the possibilities. But I think best is to buy a DVB Receiver for the livingroom. Masterlink is only for audio right?
I have a few of these lying around. https://www.amazon.de/Konvertern-Konverter-Stecker-Adapter-USB-Power-Kabel-VGA-HDMI-3-5mm-Audio/dp/B00S646VV4
They work really good as I use them for business and connecting my beamer to my BV 7-40
Kitchen: BeoPlay M3
Millemissen
Flensborg, Denmark
Posts 14,680
Tim84:
Do you mean one like this:
https://www.amazon.co.uk/Converter-FOINNEX-Computer-Projector-Portable-VGA-HDMI-Adapter/dp/B072NCTBVP
I have no experience with those - don’t know how the quality will be.
Maybe worth a try!
However the control issue will stay.
Millemissen
Flensborg, Denmark
Posts 14,680
Tim84:
Oh - dann hätte ich ja auf Amazon.de linken können 😉
Try it out, when you alread have one.
However, I’ll stay by my suggestion to use a small tv box directly on the 7-40.
Yes, ML is for audio....and control commands.
BEOVOX141
Denmark, West
Posts 711
BEOVOX141 replied on Thu, Jun 13 2019 9:45 PM
Millemissen:
The HDMI video is not available on the SCART connectors *), but it should be on the DISPLAY 2 VGA connector, so out from the 32 using VGA then in on the DVI on the 40.. ?
Millemissen:
Consider A video linked TV,- I dont see why the same rules would apply?
*) Except for some DVB solutions.. double path inside to circumvent this very issue!
BEOVOX141
Denmark, West
Posts 711
BEOVOX141 replied on Thu, Jun 13 2019 9:49 PM
Tim84:
This is from VGA to HDMI,- what would you use that for ?
Millemissen
Flensborg, Denmark
Posts 14,680
BEOVOX141:
Tim84:
Good point - didn’t even realize that in the hassle....that 7-40 has no HDMI 🤥
Millemissen
Flensborg, Denmark
Posts 14,680
BEOVOX141:
Which probably will be the case here.
Tim84
Munich
Posts 98
Tim84 replied on Fri, Jun 14 2019 7:06 AM
I know but I have the gefen switch in the livingroom so HDMI is a good choice for me ;-)
But as this means another hdmi lead in the wall I will go with a new set-top box.
Kitchen: BeoPlay M3
Page 1 of 1 (16 items) | RSS
