Hi All,
I am interested in controlling the volume of my BL90s with a Essence Wheel when streaming from a 3rd Party Streamer. I do not want. BS Core in there and I know the App can and does control volume. I also know that the BR-One can control via the Eclipse.
3rd Party Streamer >> Essence Remote >> BL90 Vol control.
Any sound advice out there would be welcome
10
Present: BL90, Core, BL6000, CD7000, Beogram 7000, Essence Remote.
Past: BL1, BL2, BL8000, BS9000, BL5, BC2, BS5, BV5, BV4-50, Beosystem 3, BL3, DVD1, Beoremote 4, Moment.
Hi, thank you STY.
I have both an Essence remote and Beolink IR (though there are many, I’m sure my original Dealer installers left that with the BL90s).
I wired according to the diagram and set the Essence in IR mode. I suspect that as you suggest the wiring is not correct or the ESsRemote is not very strong?
BTW STY,
I ended up with an Auralic Vega G2 as my streamer, placing the signal crazily enough through its own DAC and XLR cables to the Labs. I’m very pleased with the new sound and feel that I’m hearing a new “clarity or dynamic” that just was not there before via the Beovision/Powerlink routing.
Rgds
I am not sure if you have set up the essence remote correctly, you need to put the essence remote in right mode to get it control with the IR eye connected to the BL 90. Then it will work great :)
And you can use what music system you want.
If you have put it in IR mode, it should not work slove, like when you have it in bluetooth mode.
I can test it and get back her after a short test next week.
I read your post again (seethroughyou) and i can see you write you have it in IR mode.
