Found this on a Mexican site, what is it
Or check this my friend and take a close look!
Brengen & Ophalen
Its available here for MXP 160.00, USD 14.00
I dont need it, I just found it on an Mexican auction site, I also found some other very interesting items (a total of 12 posting) a Beosound 3000 (big clamper) MXP 25,000.00 like new says the seller, looks like sh1t to me, Beo4 MXP 1,700.00, no battery cap, Beovox C75 MXP 2,700.00 no frets, headphones with missing foams and cover pieces, fake Beo earphones (originals says seller), not one item that I would dare buy. Thats Mexico
13 pesos is 1 USD
I have this exactly model for my BEOCENTER 7000, Work like charm from distance up to app. 4 meters. The only thing missing is the TAPE 2 button which is I belive in the latter versions of remote.
Yes it is remote for Beocenter 7000 and works also with Beocenter 7002. It was called Beocenter Control Module and later was replaced with Beocenter Terminal which worked with BC 7007 and BC7700 and had 2 or 3 features more (I can't remember what it was)...
Vintage Bang & Olufsen
Leslie:Or check this my friend and take a close look!
I did, a Bm 6000 quad and commander for 20 euro. Way to expensive ! :-)
