hi all, just in the middle of a full house refurb and trying to get my cabling right! If I have a Beogram connected to my moment, can I then share the output with the other multi room speakers across the house?
Beovision 10, Beoplay V1, Beolab 17, Beolab 9, Beolab 4, Beosound 2, Beosound Moment x 2, Beoplay M3, Beogram 1700
Yes, indeed you can!
Yes, if the Beogram is a later model with a built in phono pre-amp, then you just need this cable to connect it to the Aux input of the Moment:-
https://soundsheavenly.com/beogram-record-players/beogram-to-non-bo-device-phono-pre-amp-receiver-amplifier-etc
If the Beogram doesn’t have a pre-amp, you will need this pre-amp kit instead, which comes with all cables needed and full instructions, ready to “plug and play”:-
https://soundsheavenly.com/beogram-record-players/pre-amp-bundle-for-bo-beogram-and-all-turntables – please choose the “Twin RCA plugs” output option for your Moment.
If you are unsure about whether the Beogram has a built-in pre-amp, please let me know the full model number and I will be pleased to confirm this.
Kind regards, Steve.
Steve.
www.soundsheavenly.com
Thank you both! Just ordered some longer cables actually Steve! As soon as I pick a beogram up I’ll be in touch for what I need.
Thanks James!
The cables are ready to post in the morning, please ask if you need any further help.
