Hi! I came back to this wonderful site! Which was addictive to me)). I recently got a luxury B&O Beocord 2000 model T, which suffered from transport! The amplification of the device does not work, it is not supplied with adequate voltage and I do not know where to check because there are 8 plates there, I am waiting for some indications from those who are hit by this problem ??? Are there differences in construction ?? between simple Beocord 2000 and luxury Beocord 2000 ??? Model Tsi Model K .Thank youj
Hi! I'm trying to reformulate my post! I'm sorry !! The problem is this ?? I recently got a luxury Beocord 2000 T that suffered from transport !! The preamp part is ok! But the amplifier does not power does not receive voltage, I I found a broken PCB in it, but I made the mistake of plugging it in without checking if there is an idea of what to check at what voltage the device is powered and if someone hit the problem. Thanks. There are 2 models! beocord 2000 simple and b & o 2000 luxury model T and model K ?? The two models are different ?? I mean construction? chassis? thank you
