BeoSound 9000 skips at the end of cd
harib0
Posts 4
harib0 Posted: Wed, Feb 13 2019 9:58 PM
Hi, I bought my 9000 mk2 few weeks ago and found out that it skips last 20-30 seconds of the cds. This happens only if cd is longer than 74 minutes. CDs which are shorter play just fine. I have lots of compilation cds and this breaks fun of using this player. Anyone knows what could be the cause of this problem?
Here is a video showing a problem
https://www.youtube.com/watch?v=v4MN95aZNCg
Peter
Siemianowice Sl., Poland
Posts 111
Peter replied on Thu, Feb 14 2019 11:46 AM
During laser repair/replacement the attention has to be paid on laser flex/ribbon cable which has to go under the arm for tension springs. It seems it is not needed but when you put the ribbon cable above it becames too long and stops laser movement at the end of a disk.
Another cause may be a dried grease on the laser shaft
harib0
Posts 4
harib0 replied on Mon, Feb 18 2019 12:24 AM
Thank you Peter for your reply. Did you get my private message?
Peter
Posts 111
Peter replied on Mon, Feb 18 2019 9:45 AM
Unfortunately, I didn't get it Confused
harib0
Posts 4
harib0 replied on Wed, Feb 20 2019 12:09 AM
Piotrze, czy zajmujesz się naprawami tych sprzętów?
Peter
Posts 111
Peter replied on Wed, Feb 20 2019 10:06 AM
Jestem szczęśliwym posiadaczem BS9000 i z racji tego, że nie ma w pobliżu serwisu naprawiam sam posiłkując się instrukcją serwisową i wskazówkami z tego forum.
harib0
Posts 4
harib0 replied on Wed, Feb 20 2019 8:09 PM
Wspaniały sprzęt. Pozdrawiam :)
Peter
Posts 111
Peter replied on Sun, Dec 8 2019 1:52 PM
I had the same problem with playing CDs which have more than 10 songs despite placing laser ribbon cable under the arm of tension springs. This is because that ribbon cable is a little too long and is bent in a shape of collapsed letter U and the bottom of that U, when laser moves backward, starts to touch the end of plastic chassis of laser mechanism with thick square reinforcement ( empty inside). The ribbon cable should go under that reinforcement but it can’t due to it’s shape. Theoretically we should bent that cable to achieve letter C shape instead collapsed U. In reality it is not possible because the distance between laser and sledge’s bottom is very short so by bending you may obtain U but wider. Such a wider U may go under that reinforcement but  doesn’t have to. Therefore I have dismantled whole laser mechanism, took a file and grinded that reinforcement to be curved. Then for smoothness I glued adhesive tape over that curve. Maybe it is not state of art engineering but I am not an engineer and it was only solution coming to my mind. At least long CDs are now played till their end.
Page 1 of 1 (8 items) | RSS
