Beolab 50 issue
Esax
Posts 323
Esax Posted: Fri, Mar 30 2018 11:07 AM
Snap sound when using wifi with beolab 50. No problem with network over cable. If you have used wifi, you must delete it in the app or it will still be used despite cable.
Beovision 7-55 MK1 red, Beolab 10 red. Beolab 50, all black. Beolab 17 broken ice. Beolab transmitter. Apple tv4 and apple express 2.
Sweden
Posts 357
Silver Member
Martin replied on Wed, Aug 28 2019 5:54 AM
Hi Esax,
Do you have any problems with yours Beolab 50 that the slave speaker looses connection with master speaker randomly from time to time? (fast flashig orange in master speaker)
Mine have lost connection 9 times Since I bought them in the beginning of June. I have an ongoing case regarding this issue.
best regards
NEW! Beovision Eclipse 65 2nd generation (G1) with floorstand (from STB Brackets), Beolab 50 front, Beolab 3 rear, 2 x Beoplay A6 linkrooms, 2xBeoremote one BT, Beosound 9000 Mark III (sw 3.4), Beosound 5 (for DLNA only),  Philips Hue (all lights in the home), Oppo UDP-203, Apple TV 4K (2021 model). Beoremote HALO, 3xBeoplay Charging pad, Beoplay M5
Esax
Posts 323
Esax replied on Wed, Aug 28 2019 12:58 PM
Hi, I had that happen 3 times since I bought them in mars last year. But I think it’s because my internet on a daily base drops to zero.
Sweden
Posts 357
Silver Member
Martin replied on Wed, Aug 28 2019 6:00 PM
Hi Esax,
The cable connection between slave and master has nothing to do with internet connection.
That menas that you have the same fault as I have. But you have not experience it so many times as I have.
I am going to get new speakers but I am not shore if it will help. Something in the hardware/software is not stabile enough yet I think.
Sweden
Posts 357
Silver Member
Hi Esax,
Page 1 of 1 (5 items) | RSS
