hi All,
my CD6500 won’t perform !
disc is rotating briefly after ‘play’ and then just stops after a few seconds - that’s it ??
I verified the +5V and -6V are present, voltage regulators are fine.
the servo boards had all caps replaced incl the “famous” one C2103 (a Vishey replacement)
+\- 15V are present.....!
some help is badly needed - can anyone assist ?
thank you
ALF
Thanks for your concern, but
i do not believe this is the case with my laser unit.
the machine acts quite erratic - i verified the laser current adjustment as per SM
but what is interesting is the fact when a disc is loaded it doesn’t initially spin to read the TOC ?
if I press play the disc spins, TOC is red and we are up and running.
if I however push the CD loaded tray in by hand the disc performs its initial spin, reading the TOC and the disc starts playing......???
i am totally in the dark about whats going on here ?
quite obvious there is something wrong here, but what ???
Alf
ALF: Thanks for your concern, but i do not believe this is the case with my laser unit. Alf
I didn't believe either! Same behaviour on my deck, sometimes working sometimes not. I dicovered that only by accident. I removed the magnetic dust with another much stronger magnet.
Back on the CD player:
i revisited the laser current adjustment, which was too low at around 23mV !!
also readjusted the metal brace that lifts the CD pug.
the player is now starting & playing the disc, however sometimes there is an awful static noise when switching tracks.....?
not sure whether this is coincidence but it seems after playing quite a number of discs it suddenly turns off......
i know the player warms up nicely, that is why I want to raise the question of a possible temp failure - all solder joints are fine, caps measure ok.
then there is the big IC on the servo board ......?
don’t really know where/what else to check......anyone any suggestions, pointers ?
happy to listen 🙏🤙
