hi,
welcome to Beoworld! I think that the green light indicates a timer has been set. To clear it, press the mute button to see if it goes out. That should restore things.
Have a look at this thread, where I have commented about repairing the buttons on my BC2300.
https://archivedforum2.beoworld.org/forums/p/30935/246002.aspx#246002
Although the main difference was that just a few of the buttons were not working. In your case, the problem could be with the ribbon connector between the keypad and the rest of the system.
Where are you located, and are you comfortable with repairing these units?
I have a spare Beosystem 2500 front panel that you can have. It's not perfect, but certainly presentable. to replace it you have to gently remove the glass doors, remove the black plastic panels, and then unscrew the front panel. There are a number of connectors that need to come off, and the clamper rod, but it's pretty simple. If you send me a dm (click on my name and then in the middle of the page you'll see a link for send an email) you can send me your info.
Thank you Bill !! Just sent you a email.
