my set up is avant 55 and beolab 18 connected wireless
I want to play amazon music through my speakers not echos speaker how do I set this up
many thanks
m welborn
Hi Malcolm,
You can link the Echo Spot into the AV input of the Avant TV to play to the Beolab speakers. for Avant mk.1, please use this cable to the 9 pin AV input:-
https://soundsheavenly.com/tv-input/136-2285-9-pin-av-cable-for-beovision-11-12-new-generation-avant-v1-and-beosystem-4-minijack-input.html#/5-length-5m
For Avant mk.2, please use this cable instead to the 3.5mm L/R In socket on the TV:-
https://soundsheavenly.com/bo-play/8-145-beolit-12-15-17-beoplay-a2-m3-m5-beosound-core-edge-and-shape-input-cable-minijack.html#/3-length-2m
Kind regards, Steve.
Steve.
www.soundsheavenly.com
