This should be easy, but I don't see how to adjust the left / right channel balance from my listening position using Beo4.
The source unit is a Beocenter 9500. I can make the adjustment using the keyboard when standing at the unit. I want, however, to make the adjustment at the listening position.
I've searched the Beo4 user manual for the word 'balance': no hits.
Thanks for your thoughts.
You need to add SPEAKER to the LIST button on the Beo4.
- Press Power and LIST together, the display should read ADD?
- Press GO.
- Press LIST until the display shows SPEAKER then GO.
- SPEAKER should then be listed under LIST.
To adjust your BC9500, press LIST until SPEAKER shows, and then use the GO button to cycle through the sound options.
(EDIT: With SPEAKER showing in the Beo4 display, press GO twice to get to balance, and then use the Volume UP/DOWN buttons to adjust.)
Thank you, Guy! Very kind of you.
I'd added AUDIO SETUP, on the assumption that it was the required menu item, and that << >> would adjust. It's a little more convoluted than that, I see, but your instructions are spot on.
No problem - happy to help.
And I've had my BC9500 for about 13 years and had forgotten how to adjust sound with the remote, so it was a good reminder for me too!
