Beosystem 4 with beolab 7-2 three strange painfull loud noises during menu switches
Luuc
Posts 6
Luuc Posted: Thu, Aug 8 2019 9:33 PM
Hello, i have hooked up my beosystem 4 with 2 beolab 8000 and have tried to hook up a beolab 7-2 to the system through PL6 and other PL outputs. But every switch in the menu on the beosystem 4 gives three very loud almost painfull sounds out of the beolab 7-2.
Does anybody know what is the explanation for this?
Thomas
Norway
Posts 60
Thomas replied on Sat, Aug 10 2019 12:34 PM
Might be a faulty powerlink cable, i would try replacing it as a first step.
Format 0  😀😎
Luuc
Posts 6
Luuc replied on Sat, Sep 14 2019 1:58 PM
Thanks for your answer. I replaced the powerlink cable. That was not the problem. But what i forgot and what i didn’t do was replacing the short powerlink -networklink cable. This was the problem. A faulthy short cable. Problem solved.
Page 1 of 1 (3 items) | RSS
