You will loos the 2 ways control with information in tunein radio.
And also the 2 ways source.
So I dont see any point to change the core, to Get IR eye.
Ir eye is only use if your core is in a other part off house, like technical room where the Bluetooth not work. Then the ir eye is a solution.
This should your local dealer could tell you:)
