I have the above remote which suddenly went on the blink. Or should I say it won't blink
So far this is what I did
1. I used a wire with batteries removed to reset it
2. I did the sound one store reset
3. I checked the batteries
4. I replaced the two capacitors
5. I measured voltage to capacitors (4.5v) to both)
6. I disconnected and reconnected the emitters and tested them (they work)
7. No light is seen with digital camera
8. I reflowed solder on the bigger joints
9. I have not put my oscilloscope on it yet
I noticed there are no pictures of the 1000 on the web. I would love to post a picture but don't know how
Bill
