hi ive a beomaster 8000 with a pair off beovox 5000 . not sure why but im not getting any sound from both 1 and 2 specker chanals both are in the on mode. ive also checked the cable to the 5000 all ok would like some advise as what else to look fore thanks
Does it work with headphones?
Is it new to you or has it worked before?
Peter
If new to you, look on the left side and there are 4 phono sockets that should be linked with two U connectors. This connects the pre-amplifier to the power amplifier and is designed to allow a graphic equaliser to be fitted. If the connectors are not there, it won't make any sound! If this is the case, a couple of phono leads can be used instead of the u connectors.
hi peter ive had the 8000 for a number of years with no problems.I switched the 8000 of as the room was being painted when pluged back into the mains nothing peter looked at the 2u connects both in place but one seems to be pushed in more than the other ?
