Hello
I recently bought a used Beolit 800 which I am actually using (sound is great!.
The pull-out antennas work OK but sometimes they're quite fragile and very easily get interfered with. It seems like there's an external antenna input in the back. But I'm not sure if such an old model needs a specific antenna - what could an example of one be? I'm thinking something compact.
Thanks,
