BeoVision 7-32 stand and sound bar with modern tv?
AndrewEcosse
Posts 77
AndrewEcosse Posted: Fri, Sep 20 2019 4:15 PM
Hi, has anybody managed to convert their BV7 32" stand to mount a newer non B&O TV? And is it possible to use the sound bar with a modern non B&O TV?
I really like the look of the unit, but the TV Panel is getting a little restrictive for connecting in games consuls etc and it's a bit small.
Thanks, Andrew.
davidr
Montréal
Posts 172
davidr replied on Fri, Sep 20 2019 4:33 PM
STBbrackets.
I had them create a custom VESA mounting plate to mate a LG 55 OLED to a 7-32 stand (motor does not work of course). Looks great.
AndrewEcosse
Posts 77
Hi David, That’s almost exactly the set up I’d like to achieve. Is there any chance you could post a photo of the mount? Did you also keep the B&O sound bar? Take care, Andrew.
AndrewEcosse
Posts 77
AndrewEcosse
Posts 77
Hi David,
Perfect I found the mount. that's exactly what I was hunting. For others here is the link...
https://www.stbbrackets.co.uk/en-GB/product/VESA-non-Bang-and-Olufsen-TV/VESA-Adapter-BeoVision-7-32
Take care, Andrew.
Peter Pan
Posts 2,088
Peter Pan replied on Wed, Sep 25 2019 5:21 AM
Thanks for the information AndrewEcosse. Yes - thumbs up
Page 1 of 1 (6 items) | RSS
