Dear members,
after the usual recap (thanks for guidance!) my Beolink 7000 works as expected. The only issue for me is that I remember faintly that it shall lay down when it switches off after some time and lifts again when touched. Mine does not. It remains upright until I manually move it down.
SW is 3.1, MOVE is set to AUTO.
Is this intended behaviour? If not, what might be the reason?
Thanks and have a nice day
Ingo
Karnayna: Dear members, after the usual recap (thanks for guidance!) my Beolink 7000 works as expected. The only issue for me is that I remember faintly that it shall lay down when it switches off after some time and lifts again when touched. Mine does not. It remains upright until I manually move it down. SW is 3.1, MOVE is set to AUTO. Is this intended behaviour? If not, what might be the reason? Thanks and have a nice day Ingo
It does not lay down when powering off. Only when put on a table, or is lifted up from the table, it moves automatically. Otherwise "Move" must be done manually.
Yours works as designed :)
/Weebyx
