I'm entering my 43rd year as owner of my B&O system. Time for some new speaker cables. When I look at the replacement (round body) 2 din plugs, I worry about the fit under the amp and into the recess in the back of the speakers. Existing plugs are flat and fit very close to each other under the amp. Are there those of you who have done this replacement that can assure me that all will fit? Thanks for your experience.
Common round plugs will fit fine.
