Hi all,
Love to know if this is possible, I assume it isn't going to work out of the box, but I know you guys will give me a good answer.
Thanks in advance
Mark
What are the speakers?
Sorry I should have said, active speakers like the BeoLab 4500 or 5000
Assuming you have sorted the power supply, the output of the 4500 through Powerlink will be the same as any other so I see no problem.
Peter
The 4500 is a 240 volt version, so it's all good then by the sound of it.
Thanks!
