Avant 32 Screen Fault.
Peter40
Posts 2
Peter40 Posted: Fri, Oct 26 2012 1:29 PM
Hi, My Avant 32 DVD picture seems to have dropped down by a couple of centimetres so that the top is lower than it should be and the bottom of the picture is not visable?
This happens when watching both Sat and DVD.
Any advice would be welcome
Pete
Pete
New Milton,Hampshire.
Posts 7
Pete replied on Fri, Oct 26 2012 1:46 PM
Hi Peter, if you pick up Beo4 and press the list you should get Format on the LCD sreen. On mine we can then press 1/2/ or 3 which changes the Format. Hope this is some help.. Andzej
Peter40
Posts 2
Peter40 replied on Fri, Oct 26 2012 1:52 PM
Hi, thanks for your reply, yes I have tried that but it does not remedy the "dropped picture" situation!
thanks Pete
Page 1 of 1 (3 items) | RSS
