Dear members,
does anyone know:
Click
Greetings,
Kai
I don’t know - but you can buy one here:
https://radioogtveksperten.dk/tilbehoer-44/diverse-56/bang-olufsen-b-o-bordholder-til-beo4-64.html
Hi Millemissen,
I have seen the ad. But that's also a used example as it seems and therefore not really telling in terms of who made that thing. Was it an item for dealers? I know there once was a Lintronic offering, but didn't that look very different? Given that the example in question here is made of metal and some work goes into that construction, I doubt it is privately made.
Of course one can question the usefulness. But a stand has the Beo 4 collect much less dust than they usually do. I see that as a plus.
You can get one from LinTronic
http://www.lintronic.dk/PRODUCTS.aspx
Beogram 6500 MMC2,Beosound Ouverture,2xBeolab 8000,2xBelolab 4000,Beolab 2,Beolab 7.2,Beo4 navi, 2xBeocom2,Serene,Beosystem 3 mk3,H6 2nd gen,Earphones E8,A8,A9 keyring,Beoplay A1,Bottle opener,Beoplay A2 active(thanks Botty)Wine Set(thanks Botty),4Ktv Samsung 55'',Beolab 7.1 with 42''Panasonic plasma,,Oppo udp-203, LinTronic.
OldJack: You can get one from LinTronic http://www.lintronic.dk/PRODUCTS.aspx
I find that one to be more beautiful
Yes,that one looks like BV1 remote
