Anyone who knows where to buy some 3 pin plugs for B&0, item no. 7220288 ?
Should be used to connect the Master Control Link cable to another room on a Beomaster 4500. I already have the MCL 2A relay box and are only missing the cable from the Beomaster til relay box.
Thanks in advance :-)
Kim
I believe any dealer or B&O repair shop has them? Or order them online, from the dealer in Struer:
http://www.bremdal-radio.dk/webshop/brugt-b-og-o/lyd/tilbehør/bo-special-speaker-plugs/
Thanks - ordered two today :-)
