I have installed a DVB-T module (not HD) into my Beovision 6-26/Type 9272 according to the “mounting instruction for DVB module kit 1404220/1446600”. I only couldn’t carry out the last step of the instructions which is “for Beovision 6 only, use ServiceTool to update to M2 SW 4.0 or higher”.
When searching for channels the module doesn’t pick up C22 at 482.0 MHz and I am therefore missing all the BBC TV channels and radio stations. All other channels are recognised without any problems.
When connecting a Panasonic TU-CT20 Freeview box via the STB controller C22 at 482.0 MHZ is found with nearly maximum signal strength and I therefore rule out that the issue is related to aerial/reception.
For Monitor Information, DTV Service Menu and Module Information see video clip.
http://www.facebook.com/video/video.php?v=10151029305766333
Does anyone know if the missing software upgrade would solve the issue and if the ServiceTool software can be downloaded anywhere?
I have connected the same aerial cable several times to the built-in freeview module and to the external freeview box. As previously the problem only occurs when connecting the cable to the built-in freeview module. The reception of all channels is perfectly fine when connecting through the external freeview box. Could the socket of the freeview module differ to socket in the external freeview box? Are there different standards for aerial plugs/sockets? The look the same to me though
The aerial cable is connected to the DVB-T module antenna socket. I assume that I wouldn't have been able to receive any channels if the cable would have been connected to the wrong antenna socket.
How can I obtain the link frequency on the masterlink modulator?
