Replace beocenter 9500 with another media player
Nelzon91
Posts 1
Nelzon91 Posted: Mon, Oct 14 2019 2:12 PM
Hello (excuse me using google translate)
I have today:
Beocenter 9500
Beolab penta 1 (active)
beovox penta (passive)
I wonder if it is somehow possible to replace the Beocenter 9500 with any other media player but keep my 4 speakers?
what do i need to do it? ..
amplifier for beovox?
I want to be able to use the speakers for my TV. i am doing it right now with an aux cable but the setting options are not so good at beocenter. My one beovox that has the longest cable sounds a lot lower than the other.
/Simon
Jaffrey2230
Washington DC
Posts 520
Wouldn’t a Sonos Amp work for your set up? Steve from Sounds Heavenly can probably provide any adapter. This would work if you want to replace CD with streaming.
B&O in my life 😊:
  • Beolab 8002 + Beolab 2 + Beosound Core with Essence Remote (Office)
  • Beolab 6000 + Beolab 11 + Beosound Core with Essence Remote (Bedroom)
  • Beoplay A9 Mk2 (Living Room)
  • Beosound 1 with wireless dock (Portable)
  • Beosound Balance (Dining)
  • Beoplay H95 (Focused listening, travel)
  • Beoplay H9 (3rd gen) (retired)
  • Beoplay P6 (Portable)
  • Beotime wall clock (hallway entrance)
  • BMW X5 50i with B&O Audio Package (Commute/drive)
lawrencejmcook
Posts 742
Hi Nelzon91,
Have you considered a BeoAmp 2 to drive your passive Penta? It has power output similar to the BeoLabs.
In terms of streaming, perhaps a BeoSound Essence MkII. This has two Powerlink outputs - one that you can use for your BeoLabs using an adaptor cable from Steve (RJ45 to RCA plugs), and another you could connect to the BeoAmp 2 (RJ45 to RJ45).
You haven’t said what kind of TV you have so it’s hard to give more specific advice.
Hope this helps,
Lawrence
Page 1 of 1 (3 items) | RSS
