Dear Beoworld,
I was wondering if anyone could offer me some advice.
I am looking at purchasing a Beocord 5500, with the hope of recording some tapes from my Mac.
Could anyone let me know if this is possible with the 7-pin connector and if so what adapter would be required.
When playing back I hope to connect to the beoplay a8 (active speaker)
Thank-you for any help
Steve, are you there? 😊
Jacques
chartz: Steve, are you there? 😊
He cant hear you he is checking headsets
I have looked at the info about the din cable - and I thought this might be an acceptable solution.
Thanks a lot for your help!
Charles
