Beovision 7 40 mk 5 ,beovision 6x3, beosound 3000, beogram 3300 , 2 x lc2, 2 x beocom 1401, beocom 6000 x 2, 5 x beo4,
, 4 x beolab 4's, form 2, h2, a2,a1 and a beolab 2 😀😀
Dom
2x BeoSystem 3, BeoSystem 5000, BeoSystem 6500, 2x BeoMaster 7000, 2 pair of BeoLab Penta mk2, AV 7000, Beolab 4000, BeoSound 4000, Playmaker, BeoLab 2500, S-45, S-45.2, RL-140, CX-50, C-75, 3x CX-100, 3x MCL2 link rooms, 3x Beolab 2000, M3, P2, Earset, A8 earphones, A3, 2x 4001 relay, H3, H3 ANC, H6, 2014 Audi S5 with B&O sound, and ambio
That's pretty much the worst thing you can do with the speaker. He should stand 60-80cm away from all objects. But try it out. Men in Black is well suited.
I would not do that either.
Looking forward to your results.
Probably won’t make a difference for a sub since the sound is not supposed to be localized. The side passive radiators as far as I know have no bearing on the sound quality. I have a BL2 and it basically a boomy sub good for movies. So this placement should be fine. My two cents worth.
B&O in my life 😊:
Thanks for all our advice.... I am still trying it in its new location.
It may be my old ears but I can't tell any difference in sound, I just wouldn't want to damage it.
For a normal constructed subwoofer with one or two forward facing speaker chassis it could work somehow but for Beolab 2 with the passive radiators I doubt that it'll work (and sound) good.
Please just try it out and let us know if you are happy with the result.
There is only 1 driver firing from the front. The sides just need a bit of airflow. If you leave it there, perhaps keep the power of it a bit lower..
OK peeps,
After listening to movies and audio (vinyl & cd/Spotify ) I can say there is no difference in sound, I have turned down the input/setting and put it in corner setting via switch.
The sub is set quite low anyway so not to destroy the neighbourhood.
I will continue with it in its current position.. Unless advised of potential damage!
Or if any sound guru's from b&o could advise
My take is that it might well make the Beolab 2 sound boomy and horrible.
However, given that I've always thought the Beolab 2 was boomy and horrible anyway - you've got nothing to lose!!
