Hello,
First post - be gentle ...
I can press the Onetouch button but tapping does not do anything
Does the A1 not have the tap feature?
In the B&O app you can set the button to do different things, check what you have it set to
Hello armandc1,
The button works fine and I can change the behaviour in the app
The issue is that in the app, it says about tapping ...
GUINNESS:Hello, First post - be gentle ... I can press the Onetouch button but tapping does not do anything Does the A1 not have the tap feature?
