I'm looking for a beocom 6000 mk2 table charger, but almost all MK2 models have a single charging cord.
I need one with the separation of power and phone line. ( My MK1 base has this ).
Or does the MK2 base operate differently?
So this https://www.benl.ebay.be/itm/Bang-Olufsen-Beocom-6000-Wireless-Phone-W-Charger-WORKS-TESTED-Maroon/303372930677 would be the one, but a MK2 version of it.
Hi and welcome to Beoworld!
As far as I know there was no Mk2 version of the combined charger/PSTN base. The Beocom 6000 Mk2 was designed to be used with a stand alone charger (triangular base), and a separate PSTN unit to connect to the phone line. It will connect to the Mk1 base, but cannot be charged by it.
Hopefully this explains the compatibility: https://www.beoworld.org/faq_view.asp?id=74
Awesome, thx for the detailed info!!
