Beovision 9. Pin code
bramble
Posts 397
bramble Posted: Wed, Nov 27 2019 8:08 PM
Hello,
Pin code supplied by local dealer has been entered twice now and screen says "wait".
If pin has been changed from one issued with tv and has now been forgotten can anything be done?
Beovision 7 40 mk 5 ,beovision 6x3,   beosound 3000, beogram 3300 , 2 x lc2, 2 x beocom 1401, beocom 6000 x 2,  5 x beo4,
, 4 x beolab 4's, form 2, h2, a2,a1 and a beolab 2 😀😀
vikinger
Vestri Kirkjubyr, UK
Posts 5,422
vikinger replied on Wed, Nov 27 2019 8:34 PM
B&O should have a master code they can supply. If you have WAIT because of making an error then, if like the old Avant procedure, you need to leave the TV for several hours before you can try again. And you must leave the TV connected to the mains.... if you unplug it then the WAIT sequence will start again.
Graham
Page 1 of 1 (2 items) | RSS
