BS Essence and Penta+S8
1990
Posts 521
1990 Posted: Sat, Nov 30 2019 5:10 PM
Hi there,
I've sold my Essence Mk2 to someone via our local classifieds site. He is trying to setup the Essence Mk2 with two Penta Mk3s + an S8 sub. The S8 works fine but the Penta's don't give any sound. Not on PL1 nor on PL2. My guess was that it's the DIN>RJ45 converter, but he claims to have tested that already.
Any of you some idea of what could be amiss? I want to help him set it all up, but am at a loss now...
lawrencejmcook
Posts 742
Suggestions:
- Is the RJ45 to DIN Powerlink adapter fully wired? I think the BeoLab with displays need all 8 pins to be wired.
- Are the Powerlink cables between the adapter and the speakers fully wired?
- Are the speaker cables daisy-chained? Try connecting each Penta directly to the Essence, without the S8.
- Are the switches on the Pentas set correctly? One should be set to L and one to R (sorry to state the obvious, but they do have an OFF setting).
Good luck,
Lawrence
Millemissen
Flensborg, Denmark
Posts 14,680
The problem is, that the RJ45/PL port on the Essence (and the newer products)  probably will not provide enough power to trigger the amps of the BL Penta’s..
There is, however a solution for that.
Please contact Steve/SoundsHeavenly direct - he should have the solution.
1990
Posts 521
1990 replied on Sun, Dec 1 2019 12:45 PM
Thanks for your help! The RJ45<>DIN connector was faulty. It’s working atm 👍
Steve at Sounds Heavenly
The cable workshop, Leics, UK
Posts 2,165
Thanks MM!
Yes, this is fairly typical of an adapter that isn't fully wired.  The Pentas should work reliably when a fully wired adapter like this one is used (the trigger current for the Pentas is quite low, as they drain the signal through a 47k resistor if I remember correctly):-
https://soundsheavenly.com/bang-olufsen/27-313-rj45-powerlink-compatible-splitter-new-powerlink-to-two-8-pin-din-powerlink-compatible-sockets.html#/20-length-02m
Kind regards, Steve.
Steve.
www.soundsheavenly.com
Page 1 of 1 (5 items) | RSS
