I have an active kit with two bl4000's linked to a bs9000 on another floor. The volume on the 4000's comes on louder than I like. How do I adjust it ?
valve1:How do I adjust it ?
Assuming you're using a Beo 4 you need "A.SETUP" from "LIST".(Maybe you will have to "ADD" the command to your "LIST" first)- Play an audio source- Press repeatedly "LIST" till "A.SETUP" is displayed on the Beo4- "GO" >> Display changes to "BASS" - adjust bass, using "STEP UP" or "STEP DOWN"- "LIST" >> Display changes to "TREBLE" - make adjustments using "STEP UP" or "STEP DOWN"- "LIST" >> Display changes to "LOUDNESS" - "STEP UP" = ON or "STEP DOWN" = OFF- Now adjust volume, using "VOLUME DOWN" or "VOLUME UP" to set the start volume- "LIST" >> Display changes to "S.STORE" - "GO" stores ALL sound adjustments, including volume at start.
That worked , thank you Vienna.
