Hello,
I recently got a Beo5 that I was willing to use for a Beosound 5 Encore.
I download 5.12 and 6.85 configuration tools and use a Windows 7 32 bits OS to install and use the software.
I manage to configure the remote, I upload the configuration without trouble. I start to use the remote, but I can't pass the zone selection. To be precise, I only use one zone called "Living Room", it displays on the remote, but nothing happen when I click on it.
I did the same process under both version of the configuration tool, but that does the same result...
Any ideas ? :)
Cheers,
Serge
Bonjour Sergi0,
If you share your XML, I can try to upload it into my remote to see how it goes. It's a Beo6 but it should behave the same way, I think.
By the way and totally unrelated, I'm still interested in your proposal for help with your blink 7000 to kill a timer on my BS2300. But I was unable to reach you directly.
Hello Matador !
Here is a link to the file : http://dl.free.fr/fJQLHRPDD
Good reminder for the BL7000. I forget about it... Sorry ! What was the test ? We can discuss that via MP for sure !
serge
Got the file! will test it tomorrow or monday and keep you update.
Im unable to reach you directly as you profile doesn't have contact for email or PM.But you should be able to send me an email by clicking on my profile name.
Finally found out... I was expecting the same kind of touch control as the one on smartphone, but I forget it is not the same technology behind :)
Everything works fine, I will now try to improve UI by adding images rather than text.
Good news,
For pictures you ca look at this thread:
https://archivedforum2.beoworld.org/forums/p/37669/286927.aspx#286927
