Hi Everyone...
Are any of you guys next to your Ouverture at this very moment and have a tape measure at hand?
If so,could you please tell me the size of one of the doors...I have a bare unit that needs new doors and i'm about to order the glass - problem is,it has no glass doors on it...Many thanks - Robin...K&R Design of Blackpool...
Do you have the little pieces to fit the doors as well??
Here you go on mine height 13 1/8". Width is 6 1/8"
Hope that helps you some
Brilliant Striker :) Got everything yes...
Merry Christmas...
Robin...
